Construction management software
Simple construction management software programs for builders and contractors | usBIM.resolver | ACCA software
Do you want to have the guarantee that your construction projects run smoothly and on schedule?
usBIM.resolver is the solution for you!
Use it for free Check out the offer
Activate one year free trial on usBIM.store
Get free access to a complete range of online software and 10 GB cloud storage
Use one of the best cloud based construction management software | usBIM.resolver | ACCA software
Cloud based construction management software
From today with usBIM.resolver you manage all the problems that arise in every phase of the construction project, always respect the deadlines, you ensure the satisfaction of customers and team members.
Video construction management software online | usBIM.resolver | ACCA software
Use it for free Ask for more info
Try usBIM.resolver, the construction management system free for one year
Free for one year in its basic version,
scalable for projects of any size
Transform a problem into a task to be solved | construction management system software | usBIM.resolver | ACCA software
Create problem tasks in just a few clicks from wherever you are, either at the office or from the construction site. Add photos, text, videos, BIM Models, DWGs or PDF files and speed up your entire project management workflow.
Efficient, secure communication | construction management platform | usBIM.resolver | ACCA software
Forget about having to find old e-mails, photos and documents that may have been sent through to different services. Communicate with others using an internal chat session connected to specific tasks in a single working environment!
Track issues through to closure | construction software online | usBIM.resolver | ACCA software
Assign tasks to the person in charge of solving certain issues, everyone involved will get an automatic notification including direct links to files or models while you can continue to keep track of the issue until it's finally closed!
Have new regulatory requirements been imposed and does the project require changes?
Your customer asked for changes concerning the electrical outlet arrangements?
Do these kind of problems sound familiar to you?
Find out how usBIM.resolver helps you solve these and other maintenance issues in just a few simple steps!
Create tasks and quickly communicate project issues to be solved | usBIM.resolver | ACCA software
During the design phase, numerous problems can arise that must be addressed in a collaborative manner with all the professionals involved to avoid errors and delays in project execution.
With usBIM.resolver, communicate problems in a simple and clear manner by creating scheduling sheets in which each project issue is transformed into tasks that are assigned to specifici professionals with whom you can collaborate.
Indicate resolution urgency and deadlines, the activities to be carried out and the people responsible so that nothing is lost and that everyone knows what to do to solve each problem.
Are you looking to try one the best construction management software free for one year?
Use it for free
Add all necessary documents to solve project issues and defects | usBIM.resolver | ACCA software
In order to effectively communicate to another professional which project issues need to be addressed and what changes need to be made, you're well aware that you need to share huge amounts of information.
With usBIM.resolver all this information is directly linked to the reference activity and can be reached simply with a click;, in order to avoid possible misunderstandings and communication errors.
Attach any type of file such as a photo highlighting the problem, a DWG or you can highlight the issue directly on the BIM model in opneBIM IFC format or in proprietary formats such as Revit or Edificius...
Use it for free
Try usBIM.resolver, the BIM construction management software free for one year
Trace the entire process of managing an issue | usBIM.resolver | ACCA software
The design of a building can be very complex and can involve several professionals.
There are in fact several teams, each with their own area of expertise, working together and as a result it can be difficult to keep track of everything that is happening.
With usBIM.resolver each professional working on the project has a clear vision of the issues to be addressed, the deadlines and the managers of each activity.
Everyone can follow the progress of solving the problem in order to better align their work and avoid delays.
Everyone manages to have full control of the project and ensure it runs smoothly, avoiding costly delays and errors.
Use it for free
Try usBIM.resolver, the construction task management software free for one year
Solve problems faster and reduce project duration by 50% or more!
Use it for free
Try usBIM.resolver, one of the top construction management software in cloud free for one year
usBIM.resolver is part of the usBIM ecosystem | ACCA software
Leverage integration with usBIM, the openBIM collaborative platform that accompanies the digital transition of your business
usBIM.resolver general contractor software is part of the usBIM ecosystem.
Learn more
The usBIM applications
What you need to know about online Construction Management Software
Construction Management software tools are used to plan, schedule and monitor the progress of construction projects.
Software solutions that include specific construction project management features helping managers assign tasks, monitor progress, and meet budget objectives.
Construction management software can be used for both small and large projects. These solutions can help save construction managers time and money while improveing project efficiency.
Construction management software can offer many advantages. They can:
  • simplify project management;
  • provide a centralized area for storing project information (from the typical architectural plans to budgeting details, through to construction schedules);
  • make it easier to track down all project issues;
  • improve communication between all members of a construction team.
This enables all information and documents to be shared in a single centralized location allowing seamless collaboration and sharing of data and resources for optimizing construction projects and avoid delays.
To choose a construction management software you need to understand how it can ensure that a project runs smoothly from start to finish.
Construction projects always involve multiple activities, the planning of which can be difficult in the absence of specific tools.
In addition, the software must allow the managers to follow the progress of the project and quickly identify any critical issues, delays, interferences.
Another fundamental feature of a construction management software is the availability of specific functions for communication and collaboration between team members, stakeholders and contractors, so that all project participants are always correctly informed and any problem can be promptly solved.
Tools for agile digital document sharing and integration with the BIM methodology should not be overlooked.
There can be various solutions used during the construction management phase considering that it is a complex process including numerous activities (planning, coordination and project supervision). ACCA software provides specific solutions for different needs, such as:
  • usBIM.project for project planning, budgeting, and task list creation;
  • usBIM.dossier for creating, archiving and document management of construction projects;
  • usBIM.resolver, the construction workflow management software for managing issues and workflows.
Yes, construction management software is designed to be used to manage specific activities by users with different roles and technical skills.
usBIM.resolver, for example, can be used by site managers, construction team managers, design teams, facility managers, BIM coordinators and BIM managers.
All those who collaborate with these figures and are part of their project or construction teams can use usBIM.resolver to work in a coordinated way and always be involved in the development of the project.
BlogLatest News
Sign in now for free
HELP
