HVAC design software
Free HVAC System Software | usMEP.HVAC | ACCA software
Edificius Module
Design your hydronic and air handling HVAC systems in 3D... Discover the power of usMEP.HVAC!
Always keep every element's placement under control and prevent problems on site. Draw in plan and 3D, size, verify, and automatically obtain technical reports, graphic sheets, and cost estimates.
Use it for free Ask for more info
HVAC system design software | usMEP.HVAC | ACCA software
usMEP.HVAC: the new technological frontier for designing and calculating hydronic and air handling systems
More precision in drawing, faster calculation, greater forecasting ability, and cost control.
Preview video usMEP.HVAC: heating for water-based HVAC system design | usMEP.HVAC | ACCA software
Ask for more info
Ask for information about Hydronic and Air Handling HVAC Systems Software
What you can do with usMEP.HVAC
Two modules for all your needs
usMEP.HVAC (hydronic)
usMEP.HVAC (hydronic)Hydronic heating and cooling systems (summer calculation coming soon) with radiators (modular and panel), fan coil units, air heaters, and radiant panels
usMEP.HVAC (air handling)
usMEP.HVAC (air handling)Air handling systems for air conditioning, thermal ventilation, and ventilation with diffusers, grilles, air outlets, filtering terminals, and ventilation valves
Plan and 3D design of systems with one or more riser columns | usMEP.HVAC | ACCA software
Design with full freedom, in plan or in 3D, hydronic and air handling systems
usMEP.HVAC applies BIM modeling from Edificius to plan or 3D design of HVAC systems.
With the software you can model a system starting from an architectural project created with BIM authoring software such as Edificius, Revit©, etc.
Ask for more info
Ask for information about HVAC system design software such as usMEP.HVAC
Archive of terminals, special pieces, MEP object configurator | usMEP.HVAC | ACCA software
You have a vast archive of terminals, special parts... and an MEP object configurator
usMEP.HVAC provides for free a rich BIM object library containing various types of pipes, ducts, fittings (bends, joints, transitions, endcaps), special parts, terminals, control valves and dampers.
Furthermore, with the BIM configurator for MEP objects, it is possible to create any component while drawing the system.
After configuring the object, you can "match" it with the corresponding market product, upload it to the catalog, and call it automatically in all new projects.
It is a unique and innovative method for object search, based on defining its functional characteristics for the project and offering maximum freedom without being restricted to catalog objects.
Automatically get HVAC system sizing with custom 3D views of results | usMEP.HVAC | ACCA software
Obtain automatic calculation of the HVAC system
usMEP.HVAC allows calculation of hydronic systems for heating and cooling (summer calculation coming soon) and air handling systems for ventilation, air conditioning, and thermal ventilation, operating both in winter and summer.
With usMEP.HVAC you can perform
  • sizing of system components (pipes, ducts, special parts, terminals, control valves, and dampers);;
  • circuit balancing;
  • verification of the HVAC BIM model designed with Edificius, without modifying the size of MEP objects;
  • recalculation of flows actually carried by the pipes;
  • customization of every system element and adding additional information;
  • verification of supply by comparing the system characteristic curve with that of the pump or fan.
usMEP.HVAC allows sizing or verifying one or more calculation circuits within the same project.
The software performs a pre-sizing of the circuit and a balancing with automatic regulation of valves, dampers, and terminals.
Pre-sizing calculates the diameters of pipes or ducts based on the fluid flow each must support and maximum values set for velocity and pressure drop.
This procedure calculates all data (spacing of radiant panels, temperatures, flows, velocities, pressure losses, head and static pressure) and minimizes imbalance between circuit branches by reducing pipe and duct diameters or using control devices (valves, dampers, terminals).
Plan and 3D design of systems with one or more riser columns | usMEP.heating | ACCA software
Leverage integration with BIM MEP modeling and get custom 3D views of results
Thanks to integration with Edificius BIM MEP modeling:
  • sizing with usMEP.HVAC automatically updates the MEP model;
  • data and calculation results are available also in views, tables, schedules, etc. of Edificius;
  • results can be analyzed through custom 3D views.
Use it for free
HVAC design software free for a month
Automatically produce project documents, cost estimates, and system renders | usMEP.heating | ACCA Software
With usMEP.HVAC you automatically obtain from the model:
  • documents (reports and tables);
  • 3D results analysis;
  • system cost estimate;
  • graphic sheets (enhanced with MEP calculation tags, system legends, and object legends);
  • workshop drawings;
  • system render.
Ask for more info
Ask for information about HVAC drafting software such as usMEP.HVAC
Modeling
  • 2D/3D modeling of hydronic heating and cooling systems (summer calculation coming soon) using various terminal types (modular and panel radiators, fan coil units, air heaters, and radiant panels);
  • design of terminal systems (with single or reverse return circuit) and radiant panel systems;
  • BIM configurator for MEP objects and BIM object library with various pipes, fittings, special parts, control valves, equipment, and terminals.
Calculation
  • sizing and verification of heating and cooling systems with terminals and radiant panels;
  • pre-sizing and balancing with valve regulation;
  • verification of the BIM model of the system designed with Edificius, without changing MEP object sizes;
  • automatic calculation of flows based on thermal or cooling power requested by system terminals;
  • system sizing allowing fixing MEP object sizes (pipes, special parts, valves, radiant panels, etc.), number of modules for modular radiators, and valve regulation;
  • sizing or verification with choice of fan speed for fan coils and air heaters;
  • verification of number of air recirculations per hour caused by operation of fan coils and air heaters;
  • verification of head and flow values of supply, comparing system characteristic curve with pump curve;
  • control diagnostics of project and parameter customization for alerts in case calculation values are out of project limits;
  • result analysis through custom 3D views.
Modeling
  • 2D/3D modeling of air handling air conditioning, thermal ventilation, and ventilation systems using various terminal types (diffusers, grilles, air outlets, filtering terminals, and ventilation valves);
  • design of air conditioning and thermal ventilation systems (operating both in winter and summer) and ventilation systems (single and double flow);
  • BIM configurator for MEP objects and BIM object library with various ducts, fittings, special parts, control dampers, equipment, and terminals.
Calculation
  • sizing and verification of air conditioning, thermal ventilation, and ventilation systems;
  • pre-sizing and balancing with dampers and control terminals;
  • circuit sizing choosing among different calculation methods (constant unit distributed pressure drop, static pressure recovery, constant velocity);
  • manual input or automatic calculation of flows based on (sensible and latent) loads requested by system terminals;
  • system sizing allowing to fix MEP object sizes (ducts, special parts, control dampers, terminals, etc.) and regulate dampers and terminals;
  • verification of static pressure and supply flow values, comparing system characteristic curve with real fan operating curve;
  • control diagnostics of the project and parameter customization for alerts when calculation values exceed project limits;
