Create the architectural 3D Model from DXF/DWG CAD files or from IFC models to produce automatic building energy calculation models
TerMus PLUS makes it as easy as possible to create the building energy model ready for the EnergyPlus™ solver. Unlike other software, TerMus PLUS doesn't require an extensive data input to derive the calculation model. It can read a wide range of datasets automatically from the building's information model. That's the true power of BIM!
Even import a CAD file in the DXF or DWG format as a reference to trace upon or simply load your BIM model in the standard IFC format.
Work on architectural projects created with other BIM authoring software (such as Edificius, Revit®, Allplan®, etc.) or on energy models created, for example, with TerMus.
Assign each architectural element (roofs, doors, windows, rooms, etc.) with the characteristics and properties required for the energy simulation.
Choose material layers, materials, generators, etc. from an extensive library of BIM objects.
Use it for free
Try the building energy analysis software for free
