Edificius | ACCA software
Compare Edificius solutions
Comparative table
  Edificius Edificius LAND
Architectural design | Interior design
Building envelopes (building envelopes, curved building envelopes, horizontal building envelopes, curtain wall, curved curtain wall, dummy building envelope, roof)
Openings and rooms (door, window, hole, roof dormer, room)
Walls, slabs, stairs, etc. (wall, curved wall, slab, staircase (1), ramp (1) , railing(1))
Columns and beams (column, beam, steel column, steel beam, custom beam, curved beam, beam gridwork (lattice), steel truss, wood truss)
Fills and surface linings (filling, curved filling, horizontal filling, lining, water expanse(1))
Other architectural objects (solid extrusion(1), solar shading, panel(1), tree(1), 3D Model(1), awning, light well, downpipe, canopy(1), light point(1),)
Plant systems (device box, junction box, electrical panel)
Terrain modeling
Terrain modeling (terrain perimeter, DXF/DWG survey, contour line, contour plan, elevation node, earthworks, linear excavation, terrain area)
Roads, squares, stairs, ramps, etc. (street, square, staircase, ramp, railing)
Walls, flowerbeds, swimming pools, vegetation (landscaping wall, flowerbed, pool, tree, vegetation, solid on terrain)
Other external arrangements (solid extrusion, panels, 3D model, canopy, expanse of water, light point)
Mechanical and Plumbing plant engineering modeling (MEP)
Pressurized pipes (pipes, flexibles, elbow joints and curves, T-fittings, Y-fittings, cross-fittings, transitions, 2-way branches, 3-way branches, double elbows, plugs, accessories)
Flue terminals and ventilation pipes (pipes, flexibles, elbow joints and curves, T-fittings, Y-fittings, cross-fittings, transitions, 2-way branches, 3-way branches, double elbows, plugs, accessories)
Air ducts (ducts, flexibles, elbow joints and curves, T-fittings, Y-fittings, cross-fittings, transitions, 2-way branches, 3-way branches, double elbows, plugs, accessories)
Equipment and terminals (equipment, hydronic terminals, aeraulic terminals, sanitary terminals, fire terminals, direct expansion terminals)
Electrical system modelling (MEP)
Electrical systems: earthing, anti-intrusion, fire prevention, home automation, video surveillance, telephony, TV, data networks, photovoltaic systems, etc.
Heritage and Historic Buildings (HBIM)
Vaults, Ribs, Wooden floor decks, Niches, Orthophoto, Damages and degradation areas.
2D Graphics, Annotations and Support for drawing
Points and guidelines, construction grids, DXF/DWG import
Lines, polylines, arcs and circumferences
2D blocks, images and raster import
Measurements of lines, angles, arcs and surfaces, elevations and spaces
Graphic forms, texts and annotations
Labels, legends and orientation
Documents (reports, tables and schedules, working drawings)
Architectural Report
Tables and schedules
Area plans
Floor plans
Sections
Elevation views
Axonometric views and cutaway drawings
Perspective views
Comparison tables (Demolish and Build)
Architectural visualization and project presentation
Scene photo-montages
Video and Animations
BIM VOYAGER (online publication and browser navigation of the 3D model)
Functions available with additional modules
AIrBIM: Rendering with Artificial Intelligence (AI)
RTBIM: Real Time Rendering (RT)(2)
BIM Video Studio(2)
VRiBIM: Immersive Virtual Reality (VR)(3)
BIM integration
EdiLus for structural calculation
PriMus for the metric calculation
4D (gantt): project time management
5D : construction cost estimating
native DWG 2D/3D CAD
SketchUp®
Blender®
Grasshopper®
Revit®
Google Maps™
Integration with other software supporting the IFC Standard
Exports
2D Exports (.DXF,.DWG,.SVG)
3D Exports (.OBJ,.SKP,.DAE,.STL,.PLY,.IFC)
  Use it for free Use it for free
(1) Architectural objects also available in Edificius LAND.
(2) Real-Time Rendering (RT) RTBIM technology - including the BIM Video Studio environment - can also be integrated in Edificius and Edificius LAND solutions with the optional RTBIM module
(3) Immersive VRiBIM Virtual Reality (VR) technology can also be integrated in Edificius and Edificius LAND solutions with the optional VRiBIM module
CONTACT US
