5D BIM software
5D BIM software | PriMus IFC | ACCA software
Coming Soon
Do you need software for quantity takeoff and cost estimating from BIM IFC models?
With PriMus IFC you get automatic quantity takeoff with visual control of the measured entities, keeping quantities and measurements always linked to the model, in a true 5D BIM.
Ask for more info  Book a free live demo
5D in BIM | PriMus IFC | ACCA software
The most innovative solution for automatic, visual quantity takeoff from BIM models in IFC format.
Video 5D BIM construction cost estimating | PriMus IFC | ACCA software
Starting from automatic entity detection in the BIM model and the guided creation of measurement rules, PriMus IFC online lets you:
  • obtain the automatic quantity takeoff for all project entities while working online from your browser;
  • have visual control of measured entities directly on the 3D model and view the quantity takeoff for the selected elements;
  • dynamically update the quantity takeoff when the IFC model changes;
  • create measurement rules and templates to reuse on other projects.
What is 5D BIM?
5D BIM is the fifth dimension of BIM.
The geometric model is usually in 2D or 3D, but by adding further information we can also obtain additional views that relate to the BIM model:
  • 4D BIM with the addition of information regarding the duration of works (time);
  • 5D BIM with the addition of material cost information and construction site building tasks.
In addition to 2D and 3D geometrical dimensions, construction phase timing and realization costs also become immediately available.
5D BIM is, therefore, a specific view that exposes project estimate and cost analysis data referring to the BIM model.
BIM Authoring software (Revit®, ArchiCAD®, ALLPLAN®, VectorWorks®, Edificius, etc.) all create a 3D BIM model with a proprietary file format (DWG, RVT, EDF, etc.). With the open and standard IFC format, it is possible to add information relating to the bill of quantities directly to the 2D/3D model produced by any IFC-Certified software.
The main difference between the traditional approach and 5D BIM modeling is the speed with which the cost of the project can be updated and changed. All you need to do is associate the project costs to the 3D dimensions of the model and, with each variation of the project, the relating cost estimate or BoQ is continuously updated.
What are the benefits of 5D BIM modeling?
Creating the 5D BIM model by associating costs to the geometric dimensions of the 3D BIM model can turn out to be a great advantage because:
  • determining project costs is faster: with 5D BIM it's much easier and faster to detect changes in costs whenever design changes are necessary. In fact, thanks to the dynamic cost estimate updating with each project variation, it's also possible to evaluate cost variations in real time and propose budget changes, even before starting the construction phase;
  • cost control is faster and more precise: 5D BIM easily shows the costs of each element directly on the 3D model. The information extracted from the BIM model identifies and quantifies elements in a very precise manner;
  • the acquisition of material quantities from the BIM model is direct: with 5D BIM, the detection of material quantities and work processes takes place on the basis of the information provided by the model, avoiding errors and inconsistencies between the cost estimate documents and the digital model;
  • save costs and time: greater control and speed of information on costs during the design and execution phase strongly minimize errors and work resources. The integration of the 5D model with time dimension (BIM 4D) allows you to simultaneously optimize project and execution costs with activity timing aspects;
To get all the advantages of the 5D BIM methodology, use PriMus IFC as your 5D BIM software.
PriMus IFC online: the 5D BIM app to use directly in your favorite browser | PriMus IFC | ACCA software
PriMus IFC online runs directly in the browser within the usBIM environment. You do not need to install desktop applications: simply sign in with your account, open the .dcfifc file and start working on the BIM model.
When you open a .dcfifc file configured for quantity takeoff, the workspace is organized into two main areas:
  • the right panel, where you create and manage measurement rules;
  • the bottom panel, where you view the embedded PriMus document with price list, quantity takeoff items and totals.
With PriMus IFC online you can:
  • work from any compatible device;
  • access data wherever you are;
  • avoid issues related to local installations and operating-system compatibility;
  • share the document with the team;
  • manage access permissions and roles;
  • collaborate on the same project with changes synchronized across connected users;
  • collaborate on the same project in real time;
  • keep the document always up to date and available online;
  • integrate automatic BIM-model quantity takeoff with the features of PriMus online.
Use it for free
Try the 5D BIM software PriMus IFC together with free technical support for a month
Choose the work item from the reference price list and link it to the quantity takeoff | PriMus IFC | ACCA software
With PriMus IFC online you can import and view BIM models in IFC format generated with any BIM authoring software.
From the bottom panel you can access the PriMus document and the reference price list.
To start the quantity takeoff:
  • open the price list;
  • identify the work item to associate with the model entities;
  • select the price item;
  • link it to the measurement rule that will automatically generate the quantities.
Use it for free
Try PriMus IFC, the 5D BIM app free for a month
Select entities from the model and PriMus IFC online identifies the elements to be measured | PriMus IFC | ACCA software
To associate the work item with the entities to be measured, PriMus IFC offers three selection modes directly on the 3D model.
Automatic selection
Select at least two similar entities in the BIM model and PriMus IFC automatically identifies all similar entities in the project.
This mode is useful when you need to measure many repetitive elements, such as walls, columns, slabs, windows/doors, or other objects with similar characteristics.
Custom automatic selection
Start from the identified IFC type and define custom filter conditions, for example:
  • name contains “external wall”;
  • height greater than 3 meters;
  • type equal to a specific IFC class;
  • model property matching a specific value.
PriMus IFC searches the model for all entities that meet the defined criteria and highlights them directly in the 3D model.
The system identifies all entities that meet the defined criteria and highlights them in the 3D model.
Manual selection
Select directly in the 3D model the entities you want to include in the quantity takeoff. This is the most suitable mode when you need to manage a few specific elements or want maximum control over the selection.
During selection, the identified entities are highlighted in color in the 3D model, so you can immediately check which elements will be measured.
Use it for free
Try one of the best 5D BIM software together with free technical support for a month
Define the measurement rule using variables, models and templates | PriMus IFC | ACCA software
Once the work item and entity type have been identified, create the measurement rule containing the descriptive and measurement information the software will apply to create the quantity takeoff.
These are the instructions PriMus IFC online uses to automatically perform the quantity takeoff. Each measurement row can include:
  • description, with free text or variables read from the model;
  • equal parts, as a multiplier;
  • length;
  • width;
  • height/weight;
  • numeric values entered manually;
  • IFC properties read directly from the BIM model.
Use it for free
Try the 5D BIM software free for a month
Use BIM variables, calculation functions and measurement templates | PriMus IFC | ACCA software
PriMus IFC online can directly use BIM entity properties as variables in measurement fields: area, length, height, volume, weight and all information available in the IFC file.
Variables are resolved automatically for each selected entity, generating the corresponding measurement rows in the quantity takeoff.
When data required for the quantity takeoff is not available among the model properties, you can also create custom variables and assign specific values to entities, such as coefficients or project-specific parameters.
For quantity calculations you can use several advanced functions:
  • counter, to automatically count entities of a specific type;
  • condensed sum, to obtain a single row with the total quantities;
  • expanded sum, to generate a separate row for each measured entity.
You can also create positive and negative rows to manage additions, deductions and subtractions directly in the measurements.
Measurement rules created for a project can be saved as models or templates and reused in other similar projects, speeding up recurring quantity takeoff work and standardizing the BIM quantity takeoff process.
Use it for free
Try the 5D BIM cost estimating software PriMus IFC together with free technical support for a month
Automatically generate the quantity takeoff for all project entities | PriMus IFC | ACCA software
Once the measurement rule is defined, PriMus IFC automatically applies it to all entities identified in the BIM model and generates the quantity takeoff and cost estimate.
BIM model and quantity takeoff always linked
You can visually check the correspondence between entities, quantities and measurements: by selecting a rule or quantity takeoff item, PriMus IFC highlights the corresponding elements in the 3D model; by selecting entities in the model, you can trace the linked quantity takeoff information.
Select elements in the model and view the related quantity takeoff
With Selection Quantity Takeoff, you can focus only on the part of the project you are analyzing: select the measured entities in the 3D viewer and PriMus IFC displays only the quantity takeoff items relevant to those elements. This makes it easier to check quantities and measurements without manually searching for the corresponding items in the full quantity takeoff.
You can check the correspondence between the quantity takeoff and measured entities directly visually on the 3D model: by selecting a rule, the system highlights the elements linked to the measurement.
From the final document you can work with the PriMus online features and complete the quantity takeoff with additional manual items, analyses and additions not present in the BIM model.
Use it for free
Try the 5D modeling software PriMus IFC together with free technical support for a month
Dynamically update the quantity takeoff whenever the IFC model changes | PriMus IFC | ACCA software
If the BIM model is modified, updated or replaced with a new version, PriMus IFC online lets you realign the quantity takeoff with the new design status.
With the Recalculate measurementscommand, the system:
  • reruns the entity search for each rule;
  • recalculates quantities using the updated model data;
  • updates measurements based on the new IFC properties;
  • removes rules linked to entities that no longer exist in the project;
  • maintains visual control of measured entities directly on the 3D model.
At the end of the recalculation, PriMus IFC generates a change report that reports any deleted rules, reductions in measured entities and variables that are no longer valid, so you can verify the effects of changes made to the model.
This gives you dynamic quantity takeoff updates whenever the IFC model changes, reducing errors, duplication and manual review work.
Use it Free
Try 5D BIM online free for 30 days
Create quantity takeoff templates and reuse rules on new BIM projects | PriMus IFC | ACCA software
Do you often create the same quantity takeoffs?
Another major advantage of PriMus IFC is the ability to reuse quantity takeoff instructions indefinitely as templates in other BIM IFC projects. After defining selection criteria, work items and measurement formulas, the system can apply the same instructions to new models
Select one or more templates from your archive, apply them to the project and automatically obtain the quantity takeoff for entities matching the selection criteria of the chosen templates; by choosing a template, you obtain a quantity takeoff that includes multiple work items.
Use it Free
Try the IFC BIM software for quantity takeoff free for 30 days
Integration with PriMus online
PriMus IFC integrated into usBIM works in synergy with PriMus online on the same quantity takeoff document.
Rules created by PriMus IFC in the right panel can be edited directly and generate items linked to the BIM model. In the PriMus document shown in the bottom panel, these items can be viewed as part of the quantity takeoff.
Items created directly in PriMus online can instead be used to supplement and complete the quantity takeoff with information not present in the BIM model: manual work items, price analyses, descriptive additions, extra items and anything else needed to complete the document.
The final quantity takeoff contains both types of items, which can be viewed and printed together from the PriMus application.
Recognition of project classifications
PriMus IFC can identify, within the IFC file, the structure of the classifications used to create the project (UniClass 2015, OmniClass, MasterFormat, etc.). This means all information is cataloged and managed, making it easy to retrieve.
A classification is a set of information (cataloged and managed) used to identify specific activities/processes; this information, shared among all professionals in the relevant sector, makes it possible to uniquely identify a given entity.
With PriMus IFC and the function for recognizing and displaying classifications associated with IFC project entities, identifying the entities to be measured becomes even easier.
IFC viewer
With PriMus IFC online you work in the usBIM 3D viewer and can open and view IFC files of 3D virtual models from any BIM authoring software such as Edificius®, Revit®, ArchiCAD®, Allplan®, Tekla®, VectorWorks®, etc. You can also:
  • load multiple IFC files in a single view to display all design aspects together in an integrated way: architectural, structural, MEP design, etc.
  • navigate easily within the 3D virtual model using the standard Zoom, Rotate and Pan functions
  • display the 3D model with different colors by element type and set object transparency to view internal portions of a 3D model as well
  • explode and break down the BIM model by floor, along both the vertical and horizontal axes
  • explore all IFC properties, including by setting custom filters and selection groups
  • view all properties and information assigned to each element of the 3D virtual model, such as volumes, areas, surfaces, distances, weights, etc.
IFC federations: quantity takeoff across multiple project files
PriMus IFC supports .dcfifc files containing multiple IFC files within the same federation. You can therefore work on federated models, for example:
  • architectural model;
  • structural model;
  • MEP model;
  • other specialist project models.
Measurement rules can involve entities from different IFC files within the same view. When one of the federation files changes version, PriMus IFC detects the update and realigns references to the new project composition. Added or removed models are detected and, once the update is complete, a dedicated report highlights the changes made to the federation.
This lets you keep the quantity takeoff under control even when the different BIM model disciplines evolve at the same time.
Structured quantity takeoff breakdown (WBS - Work Breakdown Structure)
When defining measurement rules, PriMus IFC lets you create WBS structures with an unlimited number of levels.
Once the project structure has been “broken down” to the desired level, you can assign individual items or blocks of measurement items to the WBS structure.
FAQ BIM estimating software
PriMus offers you a free conversion service for price books and price lists.
If your database is in the Excel format, you can import it directly into PriMus. Alternatively, the conversion tool, PW-CONV, already provides you with various procedures for converting price list or price book databases (for which you must detain the license for use) into a format which is compatible with PriMus.
If the conversion procedure isn't available yet, you can always request a conversion using our dedicated service available in the program's Home section. Our team will then evaluate the feasibility of the conversion process.
The PriMus suite is composed of single stand-alone software solutions designed to meet every kind of specific need:
  • PriMus, for construction cost estimates, bills of quantities and works estimates;
  • PriMus KRONO, for construction project management, time scheduling and planning;
  • PriMus TAKEOFF, for preparing Cost Estimates and Bill of Quantities from CAD and PDF files;
  • PriMus IFC, for construction cost estimates from BIM Models.
The PriMus suite comparison chart:
  PriMus PriMus IFC PriMus PLUS PriMus FULL
COST ESTIMATE, BOQS AND QUOTES
BoQ and work estimate
Bids and proposals
Analysis of construction site needs
Accounting
Importing and exporting to standard formats (XLS, DOC, ...)
Import of databases, price lists and price books
QUANTITY TAKE OFFS FROM IFC FILES
Open IFC standard formats of BIM or 3D CAD models
View and navigate 3D BIM or CAD models directly in the integrated viewer
Assignment of Price List items to BIM or 3D CAD objects
Automatic measurements with artificial intelligence from 3D BIM or CAD model
Constantly updated cost estimate when editing the 3D BIM or CAD model
Data export in Word™, Excel™ formats
QUANTITY TAKE OFF FROM CAD DRAWINGS OR RASTER FILES
Opening of standard DXF/DWG CAD DRAWING FILES
Raster (PDF, BMP, JPG, etc.) management
Associate Price list items to graphical entities
Quantity Takeoff from CAD files
Quantity Takeoff from PDF files
Take off from image files
Dynamic BoQ updating when editing drawing models
Connection with your CAD or your CAD environment in PriMus TAKEOFF
CONSTRUCTION SCHEDULING
Integration with other Project time Schedules or construction cost estimates
Works financial plan analysis and control
Works resources analysis integrated with the construction cost estimate
Work resources analysis integrated within the BoQ document
Job resources requirements analysis
Activity scheduling, resources analysis between the design and construction phases
Data export in Excel and PDF
GANTT, charts and reports printout management
Yes, PriMus gives you free access to an International Database of online price books and price lists with numerous items, materials and prices for building and plant engineering works.
4D BIM adds the time variable to the 3D model (schedule, construction site sequences, construction simulations). 5D BIM, on the other hand, adds the cost variable (quantity take-off, cost estimate, cash flow).
The typical workflow involves 5 steps:
  • Importing the IFC model generated by the BIM authoring software;
  • Defining the measurement rules (entity + price list/work item + measurement formula);
  • Mapping model objects to the reference price list items using a rule or template;
  • Automatic Quantity Take-Off (QTO);
  • Dynamic update of the quantity take-off with every model revision.
