Takeoff Software
CAD Takeoff software | PriMus TAKEOFF | ACCA software
The Takeoff software for automatic construction estimates and BoQs from DWG, DXF, PDF, JPG, BMP…
The ideal solution to save time and minimize the risk of error, without needing your own CAD software.
Use it for free   Book a free live demo
3D Takeoff software | PriMus TAKEOFF | ACCA software
PriMus TAKEOFF is the quantity takeoff software that allows you to obtain fast and accurate cost estimates by extracting measurement data directly from your project files.
With PriMus TAKEOFF extract measurement data directly from files saved in AutoCAD® DWG or DXF, Adobe® PDF, Scanned BMP, JPG image files.
Video advanced Takeoff and estimating tools | free takeoff software for construction | PriMus TAKEOFF | ACCA software
Use it for free
Try the construction Takeoff software PriMus TAKEOFF
together with free technical support for a month.
What is Quantity Take Off? Why use PriMus TAKEOFF software?
A "Quantity Take-Off" is a fundamental document for any construction industry stakeholder or project manager. It's formed of a series of manual or automated measurement operations, derived from a construction project drawing, that allow the quantity surveyor to prepare a detailed list of materials and quantities and therefore compose an accurate cost estimate of the project.
It’s an international term that usually indicates a software that is also capable of acquiring measurements from a drawing saved in one of the many electronic formats (DWG, DXF) or a raster image (previously vectorised).
PriMus TAKEOFF allows the quantity surveyor to save the drawing information and the relating cost estimate data in the DWG file by creating unity between the two document types that other software procedures do not support.
This particular technology keeps all changes made to the drawing perfectly aligned to the construction estimate data. The CAD application must of course operate directly on the DWG drawing.
Create quantity takeoff document from DWG,DXF,CAD or Raster image | PriMus TAKEOFF | ACCA software
Quickly create a quantity takeoff document directly from a DWG, DXF CAD drawing or Raster image
PriMus TAKEOFF is equipped with basic CAD drawing functions and useful digital takeoff and the well-known construction estimating functionalities provided in PriMus.
With PriMus TAKEOFF, quickly open a DWG or a Raster image and acquire precise metric data from the drawing’s graphical entities to speed up the estimating process: the quantity survey data is produced automatically and continuosly updated should the CAD drawing be updated in time.
Easily associate a drawing entity to a Price List item creating a dynamic union between the drawing and the BoQ.
Use it for free
Quantity Takeoff software free download
Draw CAD drawings using PriMus TAKEOFF CAD or your CAD application | PriMus TAKEOFF | ACCA software
Draw and edit your CAD drawings using the PriMus TAKEOFF internal CAD or your own personal CAD application
With the PriMus TAKEOFF internal CAD, you can draw or edit the graphical entities of a DWG CAD drawing. By means of the classic 2D CAD commands, the Takeoff and estimating software also allows you to change common graphical entities present in a DWG (eg, lines, polylines, arcs, circles, blocks, hatches, etc).
If necessary the same entity can be drawn from scratch to “vectorise” a Raster image.
The PriMus TAKEOFF file is a native DWG file (fully manageable by other CAD applications).
The program opens and saves files in the “AutoCAD” format (from Release 2.5 to Release 2010) and in the “AutoCAD DWG” format (from release 11/12 to release 2010) and also allows you to open DWG files created and saved with AutoCAD 2012. with these very same entities you can “vectorise” Raster images (in PDF, BMP, JPG…).
Use it for free
Free quantity takeoff software for a month
Draw your BoQ with fewer mistakes and greater control | PriMus TAKEOFF | ACCA software
Draw and prepare your BoQ with fewer mistakes and greater control
The drawing and the bill of quantities become two different views of the same objects.
When your drawing changes your Bill of Quantities is updated automatically. You can edit your drawings using the PriMus TAKEOFF internal CAD or your own personal CAD application.
PriMus TAKEOFF correctly reads the entities in the drawing and allows you to edit them together with the relating BoQ data at the same time; even when opening your modified DWG you’ll find all changes in place and of course, even when using your own CAD application.
If your BoQ data derives from a Raster image, PriMus TAKEOFF offers elementary DWG entities such as basic lines, polylines and blocks to vectorise the drawing and therefore retrive the relevant measurements (lengths, widths, areas, etc.) for quantity take-off input.
Use it for free
Takeoff program for a month
FAQ Quantity Takeoff software
There are several types of construction takeoffs, each serving specific purposes:
  • Quantity Takeoff: Measures materials and components (most common type)
  • Labor Takeoff: Calculates work hours and crew requirements
  • Equipment Takeoff: Identifies machinery and tool needs
  • Conceptual Takeoff: High-level estimates for early project phases
  • Detailed Takeoff: Comprehensive measurements for final bidding
  • Digital Takeoff: Electronic measurement using takeoff software
  • Manual Takeoff: Traditional paper-based measurement methods
PriMus TAKEOFF supports all these takeoff types, allowing contractors to perform comprehensive project analysis from conceptual planning through detailed bidding.
Takeoff methodology has evolved dramatically from manual paper-based processes to sophisticated digital workflows. Traditional takeoff required physical blueprints, scale rulers, calculators, and extensive manual calculations - a process prone to errors and extremely time-consuming. Early takeoff software introduced basic digital measurement but still required separate estimating processes. Modern takeoff software like PriMus TAKEOFF integrates measurement, pricing, and estimate generation in unified workflows. Today's takeoff technology includes CAD integration, automatic quantity updates, cloud collaboration, transforming takeoff from a tedious manual task into an efficient, accurate digital process.
Professional takeoff software should include these essential features:
  • Core Measurement Tools: Area, linear, count, and volume measurement capabilities with high precision
  • File Format Support: Native support for CAD files (DWG/DXF), PDFs, and image formats
  • Scale Management: Automatic and manual scaling for accurate measurements
  • Reporting Capabilities: Professional estimate reports and takeoff summaries
  • Collaboration Tools: Multi-user access and project sharing capabilities
  • Integration Options: Export to Excel, Word, and other estimating systems
PriMus TAKEOFF offers functionality in all these areas while adding unique capabilities like dynamic quantity updating and native CAD file integration that most takeoff software lacks.
Yes, professional takeoff software like PriMus TAKEOFF is specifically designed to handle complex architectural and engineering drawings. The software can process:
  • Architectural Drawings: Floor plans, elevations, sections, and details with automatic area and perimeter calculations
  • Structural Drawings: Rebar schedules, concrete forms, steel connections with volume and weight calculations
  • MEP Drawings: Electrical, plumbing, and HVAC systems with linear and count measurements
  • Civil Drawings: Site plans, utilities, grading with earthwork and infrastructure calculations
  • Multi-Scale Drawings: Detail sheets, enlarged plans, and section views with proper scale management
PriMus TAKEOFF's CAD integration means it understands drawing entities natively, providing more accurate measurements than image-based takeoff software that treats drawings as simple pictures.
A professional digital takeoff workflow follows these systematic steps:
  1. Project Setup: Import drawings, set scales, organize drawing sheets
  2. Takeoff Planning: Review project scope, identify measurement priorities
  3. Systematic Measurement: Work through drawings methodically, measuring areas, lengths, and counts
  4. Quality Control: Review measurements, check totals, verify against specifications
  5. Assembly Application: Apply material and labor assemblies to measured quantities
  6. Report Generation: Create professional takeoff reports and estimates
  7. Review and Revision: Final review, client presentation, and revision incorporation
PriMus TAKEOFF streamlines this workflow by maintaining dynamic links between measurements and estimates, so changes automatically update throughout the process rather than requiring complete rework.
Transitioning from manual takeoff to takeoff software requires a structured approach:
Phase 1 - Preparation:
  • Audit current takeoff processes and identify improvement opportunities
  • Select appropriate takeoff software based on your specific needs
  • Plan training schedule and implementation timeline
Phase 2 - Training:
  • Complete software training (PriMus TAKEOFF offers comprehensive training programs)
  • Practice with sample projects before working on live bids
  • Develop standard templates and assemblies for your typical projects
Phase 3 - Implementation:
  • Start with smaller, less critical projects to build confidence
  • Run parallel processes initially (manual backup) until comfortable
  • Gradually increase takeoff software usage as proficiency grows
Phase 4 - Optimization:
  • Refine workflows based on experience
  • Customize software settings for maximum efficiency
  • Train additional team members and establish best practices
Most contractors see immediate time savings and improved accuracy within the first month of using professional takeoff software like PriMus TAKEOFF.
Takeoff software improves bidding success through multiple mechanisms:Increased Bid Volume: Faster takeoff processes allow you to bid on more projects, improving your win probability through volume Enhanced Accuracy: Precise measurements reduce the risk of costly underestimation while avoiding overpricing that loses bids Professional Presentation: High-quality takeoff reports and detailed breakdowns demonstrate competence and attention to detail Faster Response Times: Quick turnaround on bid requests gives you competitive advantage, especially for time-sensitive opportunities Scope Clarity: Detailed takeoffs help identify potential issues early, allowing for more accurate risk assessment and pricing
PriMus TAKEOFF users typically report 20-30% improvement in bid win rates due to increased accuracy, professional presentation, and ability to bid more projects with the same resources.
Modern takeoff software is evolving to support contemporary construction methods:
Modular Construction: Takeoff software now handles repetitive modular components with assembly-based calculations and standardized component libraries
Prefabricated Elements: Enhanced counting and measurement tools for prefab panels, trusses, and building systems
Design-Build Integration: Closer integration between design and takeoff processes for iterative design development
Supply Chain Integration: Direct connections to manufacturer catalogs and specifications for engineered building systems
Quality Control: Enhanced verification tools to ensure prefab components match field requirements
PriMus TAKEOFF's assembly-based approach and CAD integration make it particularly well-suited for modular and prefab construction, where precise component counting and specification matching are critical for project success.
Selecting the right takeoff software requires careful consideration of multiple factors:
  • Business Requirements: Project types and complexity levels you typically handle; File formats you commonly work with (CAD, PDF, images); Integration needs with existing software systemsTeam size and collaboration requirements
  • Technical Capabilities: Measurement accuracy and precision requirements; Reporting and output format needs Customization options for your specific workflows; Training and support availability
  • Financial Considerations: Initial software costs vs. long-term ROI; Subscription vs. perpetual licensing preferences; Training and implementation costs; Potential time savings and productivity gains
  • Future Growth: Scalability for business expansion; Additional modules or features you may need; Vendor stability and development roadmap; Industry compliance and standards support
PriMus TAKEOFF addresses all these considerations with flexible licensing, comprehensive capabilities, extensive customization options, and a proven track record in the construction industry. Our free trial allows you to evaluate the software thoroughly before making a commitment.
PriMus offers you a free conversion service for price books and price lists.
If your database is in the Excel format, you can import it directly into PriMus. Alternatively, the conversion tool, PW-CONV, already provides you with various procedures for converting price list or price book databases (for which you must detain the license for use) into a format which is compatible with PriMus.
If the conversion procedure isn't available yet, you can always request a conversion using our dedicated service available in the program's Home section. Our team will then evaluate the feasibility of the conversion process.
The PriMus suite is composed of single stand-alone software solutions designed to meet every kind of specific need:
  • PriMus, for construction cost estimates, bills of quantities and works estimates;
  • PriMus KRONO, for construction project management, time scheduling and planning;
  • PriMus TAKEOFF, for preparing Cost Estimates and Bill of Quantities from CAD and PDF files;
  • PriMus IFC, for construction cost estimates from BIM Models.
The PriMus suite comparison chart:
  PriMus PriMus IFC PriMus PLUS PriMus FULL
COST ESTIMATE, BOQS AND QUOTES
BoQ and work estimate
Bids and proposals
Analysis of construction site needs
Accounting
Importing and exporting to standard formats (XLS, DOC, ...)
Import of databases, price lists and price books
QUANTITY TAKE OFFS FROM IFC FILES
Open IFC standard formats of BIM or 3D CAD models
View and navigate 3D BIM or CAD models directly in the integrated viewer
Assignment of Price List items to BIM or 3D CAD objects
Automatic measurements with artificial intelligence from 3D BIM or CAD model
Constantly updated cost estimate when editing the 3D BIM or CAD model
Data export in Word™, Excel™ formats
QUANTITY TAKE OFF FROM CAD DRAWINGS OR RASTER FILES
Opening of standard DXF/DWG CAD DRAWING FILES
Raster (PDF, BMP, JPG, etc.) management
Associate Price list items to graphical entities
Quantity Takeoff from CAD files
Quantity Takeoff from PDF files
Take off from image files
Dynamic BoQ updating when editing drawing models
Connection with your CAD or your CAD environment in PriMus TAKEOFF
CONSTRUCTION SCHEDULING
Integration with other Project time Schedules or construction cost estimates
Works financial plan analysis and control
Works resources analysis integrated with the construction cost estimate
Work resources analysis integrated within the BoQ document
Job resources requirements analysis
Activity scheduling, resources analysis between the design and construction phases
Data export in Excel and PDF
GANTT, charts and reports printout management
Yes, PriMus gives you free access to an International Database of online price books and price lists with numerous items, materials and prices for building and plant engineering works.
FAQ Virtual Reality Software for Architecture
Virtual reality for architecture is a technology that allows exploring and modifying BIM projects in immersive three-dimensional environments before their realization. Thanks to VR headsets like Meta Quest 3, HTC Vive Pro 2, or Pico, architects and designers can navigate inside 3D models, perceive the real scale of spaces, evaluate materials, lighting, and proportions, offering clients an engaging experience of the project still in the development phase.
The dynamic integration between BIM software and VR technologies occurs through specialized platforms that convert 3D models into navigable immersive experiences. Solutions like Edificius allow direct import of architectural projects while preserving geometries, metadata, and design information, enabling real-time modifications visible instantly in the virtual environment without the need for complex conversions or lengthy rendering.
The main benefits of VR in architecture include:
  • Realistic space evaluation: Accurate perception of scales, proportions, and spatial relationships in 1:1 format
  • Real-time modifications: Ability to move objects, change materials, and remove architectural elements while navigating the VR environment
  • Engaging client presentations: Immersive experiences that improve project understanding by up to 81% compared to traditional methods
  • Early error detection: Identification of design conflicts and issues before the construction phase, reducing rework by up to 50%
Yes, advanced VR technologies like VRiBIM allow direct editing of the BIM model from the immersive virtual reality environment. During VR navigation, it is possible to:
  • Add or remove architectural elements
  • Move furniture objects by grabbing them with controllers
  • Access 3D object libraries to insert new elements
  • Modify lighting scenes (natural and artificial)
  • View dynamic updates synchronized with the authoring BIM software
  • Measurement and dimensional verification
  • 1:1 scale measurement tools
  • Real-time clearance, height, and distance verification
This bidirectional workflow enables immediate feedback on design choices and real-time evaluation of modification feasibility.
Absolutely yes. VR is particularly effective for interior design and interior projects thanks to:
  • Residential space evaluation:
    Realistic perception of room dimensions, ceiling heights, proportions, natural lighting simulation at different times of day, circulation and movement flow verification
  • Furniture and finishes customization:
    Real-time movement of furniture and furnishings with VR controllers, instant material, texture, and color changes, access to 3D object libraries (furniture, decorations, accessories)
  • Specific applications:
    Kitchen design with ergonomics and accessibility verification, bathroom design with sanitary ware and finishes simulation, commercial setups (restaurants, retail, offices), green spaces and garden design at real scale
  • Effective client presentations:
    The client "lives" the space before realization, on-request modifications during the presentation, immediate choices on finishes and furnishing solutions, reduced misunderstandings and site variations, Software like Edificius includes dedicated interior design features with specialized libraries
YES. With Edificius you no longer need multiple software solutions for your architectural design. With a single software you can now deal with architecture, outdoor spaces and gardens, interior design, mechanical, electrical and plumbing systems.
Terrain and land modeling, together with outdoor spaces and gardens design aspects, are specific Edificius functions available in a dedicated environment integrated in the software.
The modeling of MEP systems (mechanical, electrical and plumbing) are specific Edificius functions available in a dedicated environment integrated in the software.
You can integrate Edificius with a wide range of ACCA software solutions.
You have dynamic integration features with Sketchup®, Grasshopper®, Revit® and Blender® for modeling free-form solids.
Also use the full power of a native 2D and 3D DWG CAD software, Edificius CAD, included for free in Edificius.
Import and export the architectural BIM model in the IFC format. Get topographic and land survey data directly from Google Maps™ satellite imagery.
Yes, AIrBIMpro2 rendering technology with Artificial Intelligence (AI) is already integrated in Edificius.
Yes, the RTBIM Real-Time Rendering (RTR) technology is provided in both Edificius with the optional RTBIM module.
Yes, the VRiBIM immersive Virtual Reality (VR) technology can be integrated in Edificius with the optional VRiBIM module.
YES. With Edificius you can collaborate in the BIM process in complete safety because it has obtained certification by buildingSMART.
BIM (Building Information Modeling) is increasingly a reality that involves collaboration, interoperability and coordination between the various stakeholders of the construction industry. With Edificius you can collaborate securely with all the best Authoring and BIM Tools certified by Building Smart International.
More information about the certification
HELP
