Free Structural Analysis Software
TRY FOR FREE NOW
Try EdiLus for free… You’ll finally be able to say that you’ve found the SMART BIM software for structural analysis
certified by BuildingSMART for IFC import
Try EdiLus for Free, the SMART solution for the structural analysis of buildings in
Easier and more reliable input thanks to BIM objects
Easier input thanks to BIM objects
Edilus is a structural calculation software with BIM technology. Model input is accomplished using 3D objects that represent the structural members such as beams, columns, walls, slabs…
A simple drawing of the structure is sufficient to provide the necessary data input for the FEM solver with nodes, loads, constraints… this makes everything really SMART.
Faster input with 3D members based on Magnetic Grids
The BIM input allows you to instantly define the strength characteristics of the objects and their spatial location. Special magnetic grids make spatial input for objects very rapid and precise. Building up even the most complex of structures will seem as simple as playing a game.
integrated FEM solver
A single software with an integrated FEM solver
The integrated finite element solver avoids having to separate the structural elements input, calculation and results analysis phases and solves the most varied geometric structures and sizes with limit state checks.
Reports and automatic Drawing Models
The technical calculation reports and drawing models with all construction details of each element of the structure are automatic. The structural engineer can take care of each element with specific program tools, so that any changes can be automatically integrated into the model.
The results are visible
EdiLus can even represent the calculation results directly on the BIM objects of the structural members. On each object you can view tensions and strains and immediately get a quantitative/qualitative analysis of the entire facility as a whole.
Integrated cost estimating
By simply assigning appropriate tariff items with their unit rates to get a precise total cost of the planned structure.
Structural analysis integrated with architectural design
By integrating EdiLus in Edificius, you can also make Architecture and Structural design aspects interact, with advanced clash detection planning and the calculating of all structural members.
