Steel Structure Design Software
Steel Structure Design Software | EdiLus STEEL | ACCA software
Are you remaining behind with your structural design software?
Enjoy all the advantages of BIM technology with FEM solver integrated in the calculation of steel structures!
Steel structure drawing software | EdiLus STEEL | ACCA softwaree
EdiLus STEEL is the BIM software for designing and calculating steel structures
In a single graphic environment you get the BIM model of simple and complex structures (with connections, bracings and trusses), the FEM calculation model, a detailed graphical analysis of the results, automatic sizing of steel connections and all the relevant construction documents (working drawings, calculation reports, etc.).
Video Steel Structure Design | EdiLus STEEL | ACCA Software
Use it for free
Free Steel Structure Design Software for a month with free technical support.
Then choose the subscription plan that suits you best.
Structural engineering regulations | EdiLus | ACCA software
International technical regulations
The EdiLus solution allows structural engineers to design and work with reinforced concrete, steel, timber and masonry structures in compliance with the Eurocodes (EC) and relating national annexes and with the Brazilian Technical Standards (NBR). More info
Steel structure modelling with three-dimensional magnetic grids | EdiLus STEEL | ACCA software
With EdiLus STEEL the modelling of steel structures is simpler and faster thanks to the three-dimensional grids (Magnetic Grid).
With the Magnetic Grid you can generate a spatial grid of magnetic nodes to which you can attach steel beams and columns directly in 3D view.
Also associate the Magnetic Grid object to a DXF or DWG CAD format drawing and automatically convert the architectural model to a valuable structural model.
The software offers Magnetic Grids of different shapes and forms (standard, pyramidal, conical, cylindrical, spherical, helical, lattice) that you can easily modify to compose a wide variety of three-dimensional models and complex geometries.
With the Magnetic Grid, quickly model even reticular structures completely in 3D view.
The integration with EdiLus CONCRETE also allows you to model mixed steel-reinforced concrete structures directly in a single model.
Use it for free
Steel design software free download
Dedicated parametric BIM objects design and modelling and an integrated structural model FEM solver | EdiLus STEEL | ACCA software
Dedicated parametric BIM objects for design and modelling and an integrated structural model FEM solver
The parametric object input in EdiLus STEEL allows you to model complex structures, check every detail and generate a detailed array of construction documents, drawings, calculations and structural checks all in a single phase.
All structural members (columns, beams, trusses, purlins, bracings, etc.) are parametric objects with their own specific mechanical characteristics and properties.
Thanks to advanced automatic design elements recognition functions, active in the magnetic grid, you can insert elements in an extremely fast, flexible and precise manner.
The software also provides a vast archive of the most widely used steel profiles: IPE, HE, Tubular, square-shaped, L-shaped, composite, etc.
The powerful integrated FEM solver optimizes and speeds up the analysis process allowing you to tackle every aspect of structural design directly within the program, without the risk of encountering structural defects and with considerable time savings too.
Use it for free
Steel structure design software free download
Modelling of trusses and bracings starting from specific library | EdiLus STEEL | ACCA software
Modelling of trusses and bracings starting from a specific library
EdiLus STEEL, the structural steel detailing software, has a specific parametric object for truss modeling.
Just choose - with a special wizard - the truss model from a specific library and define its geometry:
  • Vierendeel
  • Pratt-Mohniè
  • Howe
  • Polonceau
  • Neville,
  • English,
  • Warren
Based on the design choices made, the software automatically generates all the structural elements of the truss object.
In the same way it is possible to insert concentric vertical or pitched bracings, X, V or inverted V.
Use it for free
Steel analysis software free to use for a month
3D graphical design environment for connections | EdiLus STEEL | ACCA software
Steel member connections design is integrated within the structure calculation.
You can choose between different types of connections:
  • flanges
  • angle cleats
  • gusset plates
  • splice plates
  • with anchor bolts
The advanced graphical input of the structure also guides the user in defining the geometry in compliance with regulatory indications.
The input phase is made particularly simple and precise with the aid of a detailed view of the construction detail which is contextual to the 3D view of the connection object.
Connections management is also extended to bracings and trusses objects too.
Use it for free
Steel structure design calculation software free to use for a month
Graphical checks for instability and resistance | EdiLus STEEL | ACCA software
Graphical checks for instability and resistance each structural member
EdiLus STEEL allows the design of steel buildings in compliance with Eurocodes (EC) and relating national annexes.
Performing static and dynamic analysis of the structure with an integrated FEM solver and checks exclusively at limit states:
  • Instability checks
  • Resistance checks
  • Deformability checks
  • Capacity Design checks for members and nodes resistances.
Use it for free
3D steel structure design software free to use for a month
Real-time connection checks | EdiLus STEEL | ACCA software
Simultaneously with the calculation of the structure, the inserted steel member connections are also checked:
  • bearing verifications
  • plate punching and resistance and any additional stiffening elements
  • bolt shear and tension checks
  • weldings shear and tensile/compression check
  • verification of contact stresses for connections with reinforced concrete elements/other materials
  • extraction checks for anchor bolts
Use it for free
Use one of the best software for steel structure design for a month
3D Graphical view results with color mapping of displacements, stresses, tensions | EdiLus STEEL | ACCA software
3D Graphical view of results with color mapping of displacements, stresses, tensions...
With EdiLus STEEL consult and check the calculation results relating to members, connections, displacements, stresses, tensions, etc. in an easy to read 3D graphical representations with colour coding.
While in 3D view, a powerful self-diagnosis feature allows you to check for any unverified rods or connections.
The program also returns a color coded mapping of the safety coefficients representative of the materials work rate.
Use it for free
Software for steel structure design free to use for a month
Steel structure calculations and schedules printed or exported to excel or online | EdiLus STEEL | ACCA software
Steel structure calculations and schedules printed or exported to excel or made available directly online
Just by simply modelling the structure, EdiLus STEEL provides you with:
  • the construction drawings of the entire framing layout with connection positions and identification labels;
  • the connection construction details;
  • the floor slab frames with formwork layouts;
  • calculation reports, the geotechnical report and tables, etc.;
  • a detailed cost estimate of all elements used (plates, rods, bolts, etc.).
Thanks to the calculation data export feature, you can intuitively run a metallic structure calculation, steel beams calculations, metallic beams calculations in Excel or directly online using the usBIM, available for free together with the software.
Use it for free
Steel frame design software free download
Comparative table
  EdiLus CONCRETE EdiLus STEEL EdiLus MASONRY
Reinforced concrete elements
Columns, Slanted columns, Shear walls   50 elements 10 elements
Beam, Deep beams   80 elements 10 elements
Walls   280 m² (*) 2 elements
Slabs   280 m² (*) 2 elements
Stairs
Slab (calculation section)
Reinforced concrete elements (foundation)
Winkler beam
Plinth, Plinth on poles, Plinths in glass
Walls   280 m² (*)
Poles
Steel elements
Steel columns
Steel beams
Steel trusses
Bracing
Masonry elements
Masonry pillar
Reinforced masonry
Wall
Masonry Reinforcement interventions
Ties, pre-tensioned cables
Masonry foundation
Elements in wood and laminated wood
Timber columns/laminated wood
Timber beams/laminated wood
Timber trusses/laminated wood
Technical regulation
Eurocodes CEN-EN Eurocode (EC)
Eurocodes UNE-EN Eurocódigo (EC)
Eurocodes NF EN Eurocodes (EC)
Eurocodes BS EN Eurocode (EC)
Eurocodes NP EN Eurocódigo (EC)
Eurocodes HRN EN Eurocode (EC)
EurocodiciSS EN Eurocode (EC)
ABNT - Associação Brasileira de Normas Técnicas ABNT Associação Brasileira de Normas Técnicas (NBR) **
  Try it for free Try it for free Try it for free
NOTE:
(*) A total of up to 280 m 2 can be inserted between slabs, slabs and walls.
(**) With the "ABNT Associação Brasileira de Normas Técnicas (NBR)" it is possible to design only NEW reinforced concrete buildings.
FAQ
With EdiLus it is possible to proceed with the design and verification of new or existing reinforced concrete and ordinary masonry structures and new reinforced masonry and steel structures.
EdiLus is a structural calculation software specially designed and developed for the modeling and calculation of buildings intended for residential, public, office and commercial use. It is in this context that you can make the most of all the power, simplicity and modelling speed of EdiLus. The EdiLus solution isn't suitable for designing bridges, infrastructure works, railway networks, structures with precompressed elements and dams.
With EdiLus you can perform static and seismic linear analyses.
With regard to seismic calculations, it is possible to choose between equivalent static analysis and modal dynamic analysis.
EdiLus can be integrated with optional modules for the design and calculation of reinforced concrete structures, masonry structures, steel structures, structures with wooden elements and adaptation of existing buildings.
By integrating the appropriate calculation modules, it will therefore be possible to proceed with the calculation and verification of mixed structures.
Yes, with the Masonry module and the Concrete module it is possible to analyze seismic improvement or adaptation interventions for existing and mixed structures.
With the Masonry module, you can design seismic adjustment or improvement interventions with reinforced concrete plating, carbon fibers (FRP), fiber-reinforced materials (FRCM), ties, pre-compression cables, etc.
With EdiLus Concrete, for reinforced concrete buildings, you can design seismic improvements or adaptation interventions in which it is possible to apply both reinforcements on existing elements and insert new structural elements such as new columns, walls, share walls, bracings, etc. to model for example roofs, rised level structures and carry out an overall verification.
Accessing a special menu, you can choose the type of intervention from the following:
  • FRP Plating for Bending;
  • Plating with FRP for shear stresses;
  • Height Incrementation;
  • Reinforced concrete jacket linings;
  • Steel Jacket linings;
  • FRP plating;
  • Node Confinement;
  • Reinforcement with reinforced plaster mortar on walls;
  • Reinforcement with FRP on Walls;
  • Underpinning.
EdiLus Masonry adopts the innovative calculation method with triangular HP-SHELL schematization with multilayer variable thickening that allows you to perform the modeling of the structure in strict compliance with the different types of materials present, without assuming simplified assumptions on the data of the materials that are necessarily approximate.
The schematization with HP-SHELL elements allows you to know, from the simple structure drawn, the actual stress state of the masonry at each point and to take into account in the model all the elements characterizing an existing building in masonry (variation of materials, non-aligned holes, presence of different materials, interventions over time, etc.).
The resistant wall elements (spandrels and piers) are automatically identified and the relevant legal checks are also carried out.
You can also request the analysis of local mechanisms (overturning and facades bulging) and the design/checking of reinforced concrete or masonry foundations.
Yes, with the EdiLus Steel module you can design and calculate steel structures or individual steel elements within structures made of other materials.
EdiLus allows you to also calculate wooden elements to complete reinforced concrete or masonry structures such as roofs, canopies, etc.
The module is not designed to calculate a full wooden structure as it does not provide the specific settings for the seismic calculations of this type of structure (behavior factor, dissipative checks of the structural elements, etc.).
However, it is possible to model and calculate a completely wooden structure by defining the NON-DISSIPATIVE behavior or by paying attention to the correct definition of the behavior factor (to be defined manually) or any other settings for the seismic calculation.
EdiLus has been developed for the design of new buildings and for the verification of interventions such as improvements and seismic adaptations of existing buildings that therefore involve the behavior and verification of the structure as a whole.
It doesn't support the verification of isolated repairs.
However, this does not mean that it is not possible to model and verify/design even individual elements or some structural parts (such as roofs, foundations, etc.).
It is up to the user to demonstrate that the local intervention does not change the behaviour of the other parts or on the structure as a whole and that the interventions do not result in a reduction of the pre-existing safety levels.
With EdiLus you can export all relevant construction drawings in dwg/dxf file formats, PDFs and the 3D view of the structure in the IFC format, typical of BIM models.
Automatically obtain all the project documentation directly from the BIM model, in accordance with the most recent legislative provisions: carpentry frameworks, reinforcement schedules, general technical reports, calculation results, geotechnical report, working drawings, maintenance plans and the structure's cost estimate (with PriMus).
With regard to the steel module, you can choose between different types of connections (flange, square, gusset plates, splice plates, anchor bolts, etc.) and define the geometry with graphical input and guided in compliance with the regulatory indications.
With regard to the wood module, you can define wood-wood connections with metal type connectors for 90° intersections between horizontal beams and/or columns and wood-r.c. connections with socket-type metal connectors between wooden columns and RC foundations or between 90° intersections with horizontal beams and RC columns and/or walls.
In addition, for some situations it is also possible to define a notch type connection, in the contact areas, where the software proceeds to shape the rods appropriately by defining notches in detail and support areas to perform a timely contact tensions check.
The software provides a detailed view of the construction details contextual to the three-dimensional view of the object connection.
With special duplication functions, you can replicate each connection in all the other similar conditions present in the structure.
Please note that connections can only be entered and calculated for some types of sections and for some predefined geometric configurations.
This means that you will not "always" be able to get a full connections check.
With EdiLus, read the calculation results directly on the model.
See loads, stresses, deformations, stresses, vibration modes, safety coefficients, collapse accelerations, etc.
Also, view the various calculation results in 3D and color mapping for quick control.
Of course! You can import drawings in DXF/DWG format at various levels of the program.
We have also developed special functions that allow the automatic generation of structural objects starting from the imported dxf/dwg.
EdiLus is the first Italian BIM authoring software for structural calculation with buildingSMART international certification for IFC import and export. With EdiLus you can, for example, import the digital model of the architectural project created with an architectural BIM design software (for example: Edificius, Revit, Allplan, ArchiCAD, VectorWorks, etc.) and continue to work on the structural design and analysis aspects in 3D in accordance with the design requirements as established by other design team disciplines.
Absolutely. EdiLus allows you to export the 3D view of the structure in the IFC format typical of BIM models.
The following regulations are currently implemented in EdiLus:
  • Brazilian NBR Standards for Reinforced Concrete and Steel Construction;
  • Eurocodes.
Of course! A special Reinforcements editor allows quick modification and customization of the reinforced concrete elements with an immediate review of the structural members while keeping everything under control.
