Concrete Structure Design Software
Reinforced Concrete Design software free download | EdiLus CONCRETE | ACCA software
Are you remaining behind with your structural design software?
Enjoy all the advantages of BIM technology with an integrated FEM solver in reinforced concrete structure calculations!
Concrete building design software | EdiLus CONCRETE | ACCA software
EdiLus CONCRETE is the BIM software for the calculation of reinforced concrete structures of new and existing buildings.
In a single graphical environment, design the BIM model of your structure in an intuitive workflow and get FEM calculations, graphic analysis of the results,  automatic reinforcement bars sizing and all project documents (working drawings, calculation reports, etc.).
Video rcc design software India | EdiLus CONCRETE | ACCA software
Use it for free
Free Concrete Structure Design Software for a month with free technical support.
Then choose the subscription plan that suits you best.
Structural engineering regulations | EdiLus | ACCA software
International technical regulations
The EdiLus solution allows structural engineers to design and work with reinforced concrete, steel, timber and masonry structures in compliance with the Eurocodes (EC) and relating national annexes and with the Brazilian Technical Standards (NBR). More info
Concrete structure modelling either in plan view or directly in 3D with intelligent BIM objects | EdiLus CONCRETE | ACCA software
Concrete structure modelling either in plan view or directly in 3D with "intelligent" BIM objects
EdiLus BIM technology allows you to model structural elements (columns, beams, floors) with great simplicity with an intuitive in 2D or 3D graphical input based on intelligent parametric objects.
Each object is represented graphically and dynamically connected to a database of information that univocally identifies it in its dimensional, geometric and physical characteristics (materials, mechanical properties, etc.).
Start modelling and inserting structural members from DXF/DWG CAD drawings or from IFC file format BIM models; you can also import an architectural project directly from Edificius.
Any data assigned as an object characteristic constitutes a new input element for the calculation and each change immediately becomes a new condition to address during the verification process.
All data is stored in a single database and in a single file, with all the advantages that follow.
A powerful diagnostic is active in every phase of the design: at each modification it checks if errors have been introduced or if any errors already present have been corrected.
A simple structural modelling process to define nodes, loads, constraints... The structural calculation model is automatically recognized from the model!
Use it for free
Concrete Design Software free download for a month with free technical support. Then choose the subscription plan that suits you best.
FEM structural calculation solver integrated in the software | EdiLus CONCRETE | ACCA software
View the generated FEM model in real time based on the modelled structure and its loads.
EdiLus CONCRETE performs the necessary calculations for vulnerability analysis and for the design of interventions to improve the seismic behaviour of new and existing buildings in reinforced concrete in compliance with Eurocodes (EC) and relating national annexes and Brazilian technical standards (NBR)*.
With the integrated FEM solver:
  • view the generated FEM model in real time based on the modelled structure and its loads.
  • quickly analyze complex structures even of large dimensions.
The calculation process uses high-performance elements such as:
  • triangular HP-SHELL elements equipped with "drilling" degree of freedom;
  • the HP-BEAM element, with flexible beam, 2 hinges on each side, rigid arms, freely oriented, end junctions and elastic soil behaviour at the flexible part, allows to obtain rigorous calculation results, without the approximations deriving from less appropriate schematizations.
The solver is further enhanced by the automatic discretization function of the shell elements, which allows the designer to consider the real displacements between the various structural elements and allows to define variable thickening between the edges and the inside of the shell mesh.
Use it for free
The Structural Concrete Software free for a month. Then choose the subscription plan that suits you best.
Clear and effective graphical representations of the calculation results | EdiLus CONCRETE | ACCA software
EdiLus represents the results directly in graphical form by means of easy to read diagrams or 3D colour maps.
Loads, tensions, stresses, thanks to object-oriented technology, can be queried by the user for complete control of the performed analysis.
With a 3D colour mapped animation of the structure, EdiLus allows you to simulate and evaluate the dynamic evolution of the designed structure under the effects of an earthquake.
Use it for free
Free Concrete Structure Design Software for a month with free technical support. Then choose the subscription plan that suits you best.
Design, customization and 3D visualization of reinforcements | EdiLus CONCRETE | ACCA software
EdiLus CONCRETE automatically sizes the reinforcements of the various structural elements in compliance with regulatory requirements.
You are free to customize the reinforcement bars; each modification will correspond to the updating of the rebar bending schedules, shear and torsion diagrams.
The internal diagnostics helps you to verify correctness of any modifications made to the model in real time. In addition, you can keep manual changes and customizations made to the reinforcement schedules.
Reinforcements can also be displayed in 3D; the three-dimensional view of reinforcements allows you to easily examine the various structural elements in detail.
Thanks to the 3D reinforcement design function, each object is able to automatically increase its information level following the structural calculation with the increase in the definition and detail of the object (LOD) and the consequent level of definition of the project.
The new LOD of the project achieved following the calculation can be exported in the IFC format and shared to allow the construction of a shared digital model which is continuously defined and updated with more detail.
Use it for free
Reinforced Concrete Design Software free download for a month with free technical support. Then choose the subscription plan that suits you best.
Design of buildings with shallow and deep foundations | EdiLus CONCRETE | ACCA software
EdiLus CONCRETE allows the user to model both shallow and deep foundations.
Reinforced concrete piles can be modeled under any type of foundation (Plinths, foundation slabs and Winkler beams).
It performs the verification of vertical and horizontal limit loads and the compressive-bending and shear checks at the Ultimate Limit State for each individual pole.
It also provides the "foundation socket" object for both piles on poles and on direct poles, so as to model structures with plinths based on foundation sockets.
Use it for free
Concrete Structural Design Software free for a month with free technical support. Then choose the subscription plan that suits you best.
Design of concrete slabs with infill-blocks | EdiLus CONCRETE | ACCA software
EdiLus CONCRETE allows you to design any type of infill-block floor slab: cast in situ, prestressed joists, lattice rafters and prefabricated panels (predalles slabs).
From the simple definition of the slab structure, the "continuous beam" calculation scheme is automatically obtained with the generation of all load combinations.
Reinforcements, generated automatically, are freely customizable by the user.
Use it for free
Design and calculate solid wood and glulam elements | EdiLus CONCRETE | ACCA software
Design and calculate solid wood and glulam elements (beams, columns, trusses and purlins)
With EdiLus CONCRETE you can model roofs, porches and other timber based components to complete a reinforced concrete or mixed structure.
You can integrate one-dimensional solid wood and glulam elements into the structure (such as beams and columns with rectangular and circular section types) and complex objects such as trusses (an advanced parametric input allows you to customize the model, its composition, geometry and dimensions).
A specific function allows you to automatically insert connection purlins in just a few clicks.
Use it for free
RCC Structural Design Software free download for a month with free technical support. Then choose the subscription plan that suits you best.
Construction documents are produced automatically | EdiLus CONCRETE | ACCA software
With EdiLus automatically produce Calculation and Technical Reports, Calculation Tables, highly detailed Working Drawings and Bill of Quantities
All construction drawings are composed directly within the program by simply dragging and dropping the single drawings into the working drawings layout already pre-formatted with a wide range of title-blocks.
All produced drawings can be printed or exported in standard formats including dxf, dwg, pdf, rtf, etc.
Any changes made to the structure are immediately updated in the Project Documents and in the Bill of Quantities too maintaining a constant alignment between the structural model, the relating project documents set and the structural element quantities.
Use it for free
Use one of the best Reinforced Concrete Software.
Comparative table
  EdiLus CONCRETE EdiLus STEEL EdiLus MASONRY
Reinforced concrete elements
Columns, Slanted columns, Shear walls   50 elements 10 elements
Beam, Deep beams   80 elements 10 elements
Walls   280 m² (*) 2 elements
Slabs   280 m² (*) 2 elements
Stairs
Slab (calculation section)
Reinforced concrete elements (foundation)
Winkler beam
Plinth, Plinth on poles, Plinths in glass
Walls   280 m² (*)
Poles
Steel elements
Steel columns
Steel beams
Steel trusses
Bracing
Masonry elements
Masonry pillar
Reinforced masonry
Wall
Masonry Reinforcement interventions
Ties, pre-tensioned cables
Masonry foundation
Elements in wood and laminated wood
Timber columns/laminated wood
Timber beams/laminated wood
Timber trusses/laminated wood
Technical regulation
Eurocodes CEN-EN Eurocode (EC)
Eurocodes UNE-EN Eurocódigo (EC)
Eurocodes NF EN Eurocodes (EC)
Eurocodes BS EN Eurocode (EC)
Eurocodes NP EN Eurocódigo (EC)
Eurocodes HRN EN Eurocode (EC)
EurocodiciSS EN Eurocode (EC)
ABNT - Associação Brasileira de Normas Técnicas ABNT Associação Brasileira de Normas Técnicas (NBR) **
  Try it for free Try it for free Try it for free
NOTE:
(*) A total of up to 280 m 2 can be inserted between slabs, slabs and walls.
(**) With the "ABNT Associação Brasileira de Normas Técnicas (NBR)" it is possible to design only NEW reinforced concrete buildings.
FAQ
With EdiLus it is possible to proceed with the design and verification of new or existing reinforced concrete and ordinary masonry structures and new reinforced masonry and steel structures.
EdiLus is a structural calculation software specially designed and developed for the modeling and calculation of buildings intended for residential, public, office and commercial use. It is in this context that you can make the most of all the power, simplicity and modelling speed of EdiLus. The EdiLus solution isn't suitable for designing bridges, infrastructure works, railway networks, structures with precompressed elements and dams.
With EdiLus you can perform static and seismic linear analyses.
With regard to seismic calculations, it is possible to choose between equivalent static analysis and modal dynamic analysis.
EdiLus can be integrated with optional modules for the design and calculation of reinforced concrete structures, masonry structures, steel structures, structures with wooden elements and adaptation of existing buildings.
By integrating the appropriate calculation modules, it will therefore be possible to proceed with the calculation and verification of mixed structures.
Yes, with the Masonry module and the Concrete module it is possible to analyze seismic improvement or adaptation interventions for existing and mixed structures.
With the Masonry module, you can design seismic adjustment or improvement interventions with reinforced concrete plating, carbon fibers (FRP), fiber-reinforced materials (FRCM), ties, pre-compression cables, etc.
With EdiLus Concrete, for reinforced concrete buildings, you can design seismic improvements or adaptation interventions in which it is possible to apply both reinforcements on existing elements and insert new structural elements such as new columns, walls, share walls, bracings, etc. to model for example roofs, rised level structures and carry out an overall verification.
Accessing a special menu, you can choose the type of intervention from the following:
  • FRP Plating for Bending;
  • Plating with FRP for shear stresses;
  • Height Incrementation;
  • Reinforced concrete jacket linings;
  • Steel Jacket linings;
  • FRP plating;
  • Node Confinement;
  • Reinforcement with reinforced plaster mortar on walls;
  • Reinforcement with FRP on Walls;
  • Underpinning.
EdiLus Masonry adopts the innovative calculation method with triangular HP-SHELL schematization with multilayer variable thickening that allows you to perform the modeling of the structure in strict compliance with the different types of materials present, without assuming simplified assumptions on the data of the materials that are necessarily approximate.
The schematization with HP-SHELL elements allows you to know, from the simple structure drawn, the actual stress state of the masonry at each point and to take into account in the model all the elements characterizing an existing building in masonry (variation of materials, non-aligned holes, presence of different materials, interventions over time, etc.).
The resistant wall elements (spandrels and piers) are automatically identified and the relevant legal checks are also carried out.
You can also request the analysis of local mechanisms (overturning and facades bulging) and the design/checking of reinforced concrete or masonry foundations.
Yes, with the EdiLus Steel module you can design and calculate steel structures or individual steel elements within structures made of other materials.
EdiLus allows you to also calculate wooden elements to complete reinforced concrete or masonry structures such as roofs, canopies, etc.
The module is not designed to calculate a full wooden structure as it does not provide the specific settings for the seismic calculations of this type of structure (behavior factor, dissipative checks of the structural elements, etc.).
However, it is possible to model and calculate a completely wooden structure by defining the NON-DISSIPATIVE behavior or by paying attention to the correct definition of the behavior factor (to be defined manually) or any other settings for the seismic calculation.
EdiLus has been developed for the design of new buildings and for the verification of interventions such as improvements and seismic adaptations of existing buildings that therefore involve the behavior and verification of the structure as a whole.
It doesn't support the verification of isolated repairs.
However, this does not mean that it is not possible to model and verify/design even individual elements or some structural parts (such as roofs, foundations, etc.).
It is up to the user to demonstrate that the local intervention does not change the behaviour of the other parts or on the structure as a whole and that the interventions do not result in a reduction of the pre-existing safety levels.
With EdiLus you can export all relevant construction drawings in dwg/dxf file formats, PDFs and the 3D view of the structure in the IFC format, typical of BIM models.
Automatically obtain all the project documentation directly from the BIM model, in accordance with the most recent legislative provisions: carpentry frameworks, reinforcement schedules, general technical reports, calculation results, geotechnical report, working drawings, maintenance plans and the structure's cost estimate (with PriMus).
Steel member connections design is integrated within the structure calculation.
With regard to the steel module, you can choose between different types of connections (flange, square, gusset plates, splice plates, anchor bolts, etc.) and define the geometry with graphical input and guided in compliance with the regulatory indications.
With regard to the wood module, you can define wood-wood connections with metal type connectors for 90° intersections between horizontal beams and/or columns and wood-r.c. connections with socket-type metal connectors between wooden columns and RC foundations or between 90° intersections with horizontal beams and RC columns and/or walls.
In addition, for some situations it is also possible to define a notch type connection, in the contact areas, where the software proceeds to shape the rods appropriately by defining notches in detail and support areas to perform a timely contact tensions check.
The software provides a detailed view of the construction details contextual to the three-dimensional view of the object connection.
With special duplication functions, you can replicate each connection in all the other similar conditions present in the structure.
Please note that connections can only be entered and calculated for some types of sections and for some predefined geometric configurations.
This means that you will not "always" be able to get a full connections check.
With EdiLus, read the calculation results directly on the model.
See loads, stresses, deformations, stresses, vibration modes, safety coefficients, collapse accelerations, etc.
Also, view the various calculation results in 3D and color mapping for quick control.
Of course! You can import drawings in DXF/DWG format at various levels of the program.
We have also developed special functions that allow the automatic generation of structural objects starting from the imported dxf/dwg.
EdiLus is the first Italian BIM authoring software for structural calculation with buildingSMART international certification for IFC import and export. With EdiLus you can, for example, import the digital model of the architectural project created with an architectural BIM design software (for example: Edificius, Revit, Allplan, ArchiCAD, VectorWorks, etc.) and continue to work on the structural design and analysis aspects in 3D in accordance with the design requirements as established by other design team disciplines.
Absolutely. EdiLus allows you to export the 3D view of the structure in the IFC format typical of BIM models.
The following regulations are currently implemented in EdiLus:
  • Brazilian NBR Standards for Reinforced Concrete and Steel Construction;
  • Eurocodes.
Of course! A special Reinforcements editor allows quick modification and customization of the reinforced concrete elements with an immediate review of the structural members while keeping everything under control.
